Re: Evinrude 150 HP Cross-Scavenged?
Thanks for the response Joe.
I purchased the boat about three years ago on a whim, it is a 1986 Mach 1, looked good but when I got it home I realized the transom had been getting wet and was rotted and the fiberglass was cracked. I repaired it and had the fiberglass repaired and now I think I have a good transom for a few years.
I was laid up for about a year with shoulder surgery and last year finally got the motor back on and in the water! I had some trouble getting it running, took it to a mechanic and replaced all the electronics except for the coils, rebuilt the carbs and thru a set of plugs in it. The mechanic is an Evinrude guy seemed very knowledgeable, said the motor checked out good also changed the oil in the lower unit.
I had the motor on on a steel table in the parking lot of the shop I work at. Here in the southwest we get monsoons with quit a bit of lighting and wonder if there was a lighting strike close by that messed up the electronics?
I've had a few outings, a few just running around the lake and then pullings my kids (read adults) in a tube, having fun. This year I am getting the boat ready and noticed that as I was priming it there was fuel leakage from between the pump seams. I have always been concerned about the pump so I was also mixing oil into the gas (double oiling). The VRO was working good I think as the oil in the oil tank was being used. I did not want to spend the extra money on the pump but now it seems I have to.
I was reading about the crossflow motor and thought the VRO hooked up differently, a fitting between two crank fitting but the pump I have now only has one line into the crankcase to run the pump. As I understand it the cross-flow is just a cylinder design to exchange the fuel mixture.
So I have the new VRO part number, need to get a new harness because my old pump did not have a "No Oil" warning on it.
The two issues I have been experiencing is the motor not wanting to idle and then running WOT it would cut out on me, it did not die but dropped back to an idle, I had to pull the throttle back to neutral and then to forward and she ran again. Maybe fuel pump issues?
Hope I did not ramble to bad just wanted to give a little history
