Evinrude 150 fuel pumps
chuckblechle
I have a 1983 evinrude E150TRLCTE with new updated fuel pumps. The issue is that the official parts diagram shows the top and bottom pumps are different P/N. The original top 0393648 and bottom 0393650. Both pumps were replaced with pump number 0438559 the direct superceeded P/N for the top pump. What is the difference between the two pumps?
I have a problem with the motor shuttering around 1400-1800 rpms but seems to run well at an idle and top end. When the motor shutters i can see fuel getting pushed back up into the clear fuel filter at the tank. Any thoughts if spending the $140 for the correct pump may solve my problem?
chuckblechle
Anyone know the difference between the top and bottom fuel pump on an 1983 evinrude 150?
Honorary Supreme Mariner
There may be a difference in the springs internally.----One pump feeds the other.-------Now these pumps are easy to take apart for inspection.---I would do that before spending a single dollar on this motor !-----Others will argue that point.----Any other trouble shooting done on this motor ?----Compression test ?----Checked for spark on all 6 leads ?
chuckblechle
I completed a compression test and all were 95 PSI +-1 PSI, Used a spark tester at 7/16 and all looked good also, replaced fuel lines, cleaned carbs and replaced 1 jet. Took pumps apart and did not see any issues.
