evinrude 150 ficht
mann9685
Hope someone could answer this question i have 150 model #e150fpxsif serial g 04907069 with a blown powerhead which was made in 2000 i found a motor with model# e150fpxee serial# g 04681780 which was made in1999 r there any differences between the two from the pics of both motors they look the same but the seller is 4 hours from where i live so icannot be sure and hate to travel that far only to find out it is not an exact replacementment any help would be appreciated
Faztbullet
If you have the early style 2000yr without the poppet valve on bottom left side of block yes it will work
emdsapmgr
Up through 1999 model year, the Fichts were made by OMC. Those were the problem engines. The 2000 and up are Bombardier engines and had many improvements over the 1999's. You may be able to find out if any service bulletins are still open for the 1999 serial number.
