blue.monkey
Thread starter- Joined
- May 22, 2002
- 34
Hello,<br />I have an evinrude 150, year 1989, ser # E150TXCEM. I have a problem with intermittant very hard starting and coughing, bucking and power loss at the same time. I went to the dock today to look at it and replaced plug wires because they looked damaged. I also did a compression test, it was ok. It started great, I exersiced the throttle and it ramped up nicely. I let it run for about 15 minutes, and it instantly started to run poor, ( I periodically ran the throttle plates up to prevent it from loading up). when it is running poor, it bogs down and stalls. And when i left it moments ago it would not restart at all. Although the VRO system is installed, I run 50:1 in the tank because the VRO does not appear to work. When i was testing it today I crimped the oil injection hose to eliminate the possibility of loading up on to much oil. <br />Any advice would be greatly appreciated. <br />Thanks,<br />Kevin
