Evinrude 135 electrical problems
chadc1
HELP!!, I'm running a 1973 135hp Evinrude Starflite. The problem is, on cool mornings I have no electrical power when trying to start the motor, (no crank, no power to gauges, nothing when key is turned). <br /><br />I can start the motor by useing jumper cabels, from the battery, directly to the starter motor. Once the motor runs for about ten to fifteen minutes, I have power to my gauges, and have no other problems for the rest of the day<br /><br />Any suggestions would be greatly appriciated, Thanks!
OBJ
Re: Evinrude 135 electrical problems
Ahoy chad....welcome to the forums...<br /><br />First thing to do is check all your main electrical connections starting at the battery. Make sure they are clean and tight. I would bet you are going to find a connection that seems tight but isn't or one that is a little dirty. Don't forget the engine ground from the battery also.<br /><br />Keep us posted....thanks.
