robert.barnes
Thread starter- Joined
- Oct 4, 2006
- 62
i rebuilt a evinrude 120 looper i got the motor with all new parts and macine work done i just had to put it all back to a running motor i put all new carb kits in and new recirce valves all new hoses and new plugs i am still running the motor on the break in i have about 8 hours on it running 25 to 1 ratio the motor runs great from 1500 rpms on it has tons of torque but my problem is idel or low rps no wake it acts like it is missing fire or something if you run it long babying it it wont open up it bogs out and u have to give at least half thotle to start it also at idel if it starts to die if you push the chock it cleans up a bit and will stay running but the primmer buld stays tight also it has a new fuel pump any help would be thanked alot i just did not know if this was normal for break in with 25 to 1 ratio also plugs r black not carboned up just black
