Evinrude 115 Ocean Pro
Pai
Hello Again from sunny Thailand,<br />Thankyou for your replies.<br />We are using a workshop manual to check stator, power pack etc, and have all the 'gear' but the problem is very intermittent. Your suggestion of key switch is a good possibility and I have ordered a nnnnew one from Bangkok. Will keep you posted about results,<br />Best regards,<br />Pai
clanton
Re: Evinrude 115 Ocean Pro
IF you have a peak reading meter, connect to pack output to coil, run engine until it misfires, check all 4 cylinders. Check for coil arcing to metal plate between the coils and power pack. They had enough problems with the sensors, that they now come with power pack, with increase in cost.
