Evinrude 115 lower unit replacement.
bharrisss90
I'm fairly new to outboards and have to replace a lower unit, followed the service manual and got it buttoned up but once its all buttoned up smooth they propeller shaft doesn't spin freely like the other engine. It is a factory new lower unit from BRP filled with fresh oil. Any insight or advice will be appreciated.
Honorary Supreme Mariner
Did you turn the shift rod ?------Did you adjust the shift rod height before installing ?
