evi motor,year,fuel mix ????'s
daisy mae
I have an 80? something 25 horse evinrude outboard i have just picked up...model #TE25ELE1D? serial#G?264501. the guy i bought it from said to mix fuel 50-1. the problem is it is fouling plugs out and hard to start. could anyone help me with the year and proper fuel mix?
ob
Re: evi motor,year,fuel mix ????'s
Model number should read TE25ELEID.EI means it's a 1991 model.Mix is 50:1 .What sparkplugs are you currently using?Engine calls for QL77JC4 or QL82C gapped at .030".
daisy mae
I am running QL77JC4 Champions. It just seems like the carb is running too rich. It has a hard time winding out. The starter has been replaced and that's all the work done to it recently. I'm scared to lean it out and ruin a piston. Thanks
ob
Determine where the idle mix screws are presently set by screwing them clockwise until they seat and counting the turns.1 1/2 - 2 turns open should put you in the ballpark.Fine tuning may be necessary.
