happy hooker
- Jun 10, 2002
- 34
i have a 1959 35hp. johnson. it has not run for 20 years. i rebuilt the carb,installed new points cond& coils. put all new seals and gaskets in lower unit. motor starts up fine idles ok but does not get up tp full powercheched compresson 115 on 1& 120 on other.have manual set timing as instuucted, points set at..020changed gas ,changed oil mix fron 24/1 to 50/1 after 30 minutes running plugs are coversd with a black sotty carbon not wet dry. tried lean out low speed runs better but now so lean needto choke or rich up low speed to start .needle jets are good.in 20 minutes it will burn 3 gal of gas.no matter what i do plugs come out the same covered with ablack sotty dry carbon in 15 minutes.
