evenrude trolling
dbone
I bought an evenrude trolling motor and have no idea how many pounds thrust it has the model is EBHL4A the serial no is H2632993 it is 12/24 volt if anyone knows anything thank you:)
HondaPower
Re: evenrude trolling
Not sure if this is any help, my manual has a listing for a BFL4A. The description is Deck Mounted, Foot Controlled, 12/24V, 41 Lbs thrust, 6 speeds, Maximum Current -Amps 29. The manual covers late 90's OMC trollers. Hope this helps.
dbone
The one I have is not foot controled. Thank you anyway thats probly close
HondaPower
Took another look at the manual now that I am wide awake, and there is a listing for a BHL4, Deck Mount, Hand Control, 12/24 Volt, 43 LBs Thrust, Max Amps 33, 6 Speed + Jog, Shaft Length 42". This is probably closer to what you have, don't know how I missed it the first time.
