evenrude owner - Oil Leak
kmruble
I have an oil problem with my 1981 90 hp evenrude,it runs fine but when i take it out of the water after running it i have an oil leak around the exhaust cover any suggestions
emdsapmgr
On these older crossflows, it's common for the powerhead base gasket to leak after many years of use. Two things can happen: 1. exhaust will leak around the bottom of the powerhead, causing exhaust gas to get recirculated into the carbs. 2. The leaking oil/tar will run down from the powerhead, onto the outside of the midsection. Sound familiar?
kmruble
That sounds like my problem, which gasket should I get. the lisy
ting doesnt have a power head gasket.
emdsapmgr
All of the factory parts lists show the powerhead base gasket. Check out this factory website: epc.brp.com. The gasket you need is item #18 on the midsection diagram. It's not on the powerhead diagram.
kmruble
all websites I go to show #18 as a by-pass cover gasket,on the cylinder and crankcase diagram
Vic.S
is it # 37 on this diagram
convert
emdsapmgr
The flat-rate on removal and reinstallation of the powerhead is something like 3 hours. Not really difficult, just time consuming. You will need to lift the powerhead just high enough to repl that gasket-also not an easy task.
