Re: Evenrude fuel starvation
Poor fuel delivery problems can be caused by many things: <br />>tee into the suction side of the pump (at the pump) with a vacuum pressure gauge(cheap) and a piece of clear hose inline with the main fuel line. Start engine and observe vacuum. If above 3"HG, suspect a restriction between the pump and the fuel in tank(vent/cap plugged, hose kinked, hose plugged, anti-spill/syphon valve) Any bubbles in the clear line suggest air leaks in the suction side.<br /><br />>reinstall all connections in the suction side and tee in on the pressure side of the pump. Start engine. Pressure should be 1-3psi pending on model. If pressure is low, the pump diaphram, valves, and vacuum supplied by motor are in question. Remove the pump and check the crankcase port to engine for blockage. If its clear, the problem is in the pump.<br />If pressure was normal, but still no fuel to carb, check the inline filter(if any) <br /><br />
