Ethanol
cjwheel
I am rebuilding by carb,fuel pump, and primer assembly on my 2000 25 hp Mercury. I am also replacing all fuel lines and fuel tank. I am wondering if what i have heard about the ill affects of ethanol in fuel are true? Will a fuel stabilizer counter these ill affects or should i only use non ethanol fuel?
Blaw
Re: Ethanol
I just spent $1556.00 to replace two fuel pumps because of this. I promise I will use a stabilizer for now on.
cjwheel
Re: Ethanol
Sorry folks, Im new to the forum and I see there are a thousand threads related to ethanol. I will search the previous threads as this topic is not new. thanks
RogersJetboat454
Re: Ethanol
Most of what you hear about ethanol is bunk.
If you intend to leave fuel unused for months on end, a stabilizer is a good idea regardless of the fuels formulation.
If the fuel is going to be used with in a month, I would say you should be fine.
A year 2000 engine should have rubber on it compatible with ethanol. Don't know if your replacing all that because it needs it, or because you think it needs it.
JB
Re: Ethanol
Welcome to iboats, cjwheel.
Thanks for this post. It is a breath of fresh air for the Mod squad. :)
