Richard1991
Thread starter- Joined
- Feb 10, 2023
- 10
Can anyone tell me Can or how can I undo the the automatic oil injection system without messing with the emm so I can just mix the gas and oil myself
Thanks I kind of figured thatSorry---That will not work on an E-TEC !!!!------You must stick with the oiling system as designed.
suggest you consult with the experts on the E-TEC user group and use the search utility .It's leaking oil out of the bottom port in the front port into the air silencer and just figured it would be easier than finding the problem and it's shutting off when I give it the gas
Ok I'm going to take it to the mechanic sounds to difficult to me I do appreciate the infosuggest you consult with the experts on the E-TEC user group and use the search utility .
Stalling.... have you at least done some basics like checking fuel filters and the sneaky one in the VST injector return hose . see manual
Faulty VST at may be causing some grief... sending fuel into the crankcase instead of just vapors to be burnt off
you really need EV Diagnostic software to service these engines to see if the EMM has picked up any faults
Evinrude Diagnostics Version 5 A Guide To Getting Started
EVINRUDE DIAGNOSTICS VERSION 5 A GUIDE TO GETTING STARTED September 2021 INTRODUCTION This guide is primarily intended to help Evinrude E-TEC owners. The words...docs.google.com
That is caused by bad recirculation check valves. Easy fix, just buy the new oil recirculation check valves or take the old ones apart and clean then out. They sometime like to stick. They act like a pump which sucks the oil from the bottom of the crankcase and puts it in the top.It's leaking oil out of the bottom port in the front port into the air silencer and just figured it would be easier than finding the problem and it's shutting off when I give it the gas
Probably... idk much about the carbed engines though - I only mess with E-TEC. Maybe I'm part of the wierd crowd that likes the world's hated engines - HPDI, optimax, ETEC. LOLDifferent check/recirc system on Etec and carbed engine
