Etec 135 h.o.
BraydenE
New to the forum here. I have a 2015 135 ho etec and it's time to change my fuel lines. Where is the best place to order new lines and which one do I need to order? I know I need 3/8 id, ethanol resistant and needs to be uv resistant as well. I was also looking to add a fuel gauge, which mine currently does not have.
Thanks
Faztbullet
You do not need to change lines under cowling. The oil supply and return I have never seen replaced....
Agreed----Why do you think lines need replacing ?----And these motors came with a multi year warranty I think.
Joe Reeves
If for some reason you feel the need to have new fuel lines on hand, of various sizes... they can be purchased at any automotive parts store and various hardware stores that sells mowers, pressure washers, etc. I used those lines for many years... never had a problem.
82rude
There should be no need to change the lines under the cowling if thats what your talking about.As for warranty my 2011 which was bought in april of 2012 comes out of warranty april of 2018!There was a special deal a couple of years ago where they gave you a 10 year warranty i believe.Those under hood lines should be good for a very very long time.
jimmbo
That's a new one... I have never heard of a time interval for replacement of fuel lines? Internal or from the tank to the engine.
As for the fuel gauge... What make is the boat? I haven't seen built in tanks without fuel senders and gauges since I can't remember when
BraydenE
I'm talking about the lines from my cowling to my gas tank. My bulb kept collapsing the other day. My vent on my tank was open. It is not a built in tank.
Joe Reeves
The fuel primer bulb will collapse ONLY if there is a fuel restriction between the bulb and the fuel supply.
jimmbo
To BraydenE. Thanks for the needed info
