est conversion issues
skiprspd3
After hooking up everything per the supplied instructions. I have no power to the purple "+12v" wire to my coil.
Any help would be apperciated. This is a 3.0l merc
Don S
Re: est conversion issues
Did you turn the igntion key to the run position? Make sure the lanyard kill switch is on.
If ok, On the ignition switch, check for power to the B terminal on the (red/purple wire), and on the I terminal (purple wire) when the key is in the on position
skiprspd3
I do believe the ignition switch is working correctly. Its very hard to tell the colors your describing, because everything under the dash is wired with orange wire. I used a test light to make sure the ignition when turened to the on position has one leg energized. Also when turned all the way to the start position the other leg on the ignition is energized. I'm not sure where I'm losing my power, but I'm getting very frustrated with this boat. It's been a while since it's been in the water. I will run a new wire from the ignition switch if some one can just tell me where to hook everything up properly. I'm not all that confident with electrical repairs. I know enough to basically get me in trouble.
Thanks in advance for any help.
skiprspd3
So just to add some more info. This boat is a 1990 Larson.
On the wiring diagram there is a purp/yellow coming from the starter to the +side of the coil. Connected to that was the purp wire, so I seperated them and connected the purp to the purp on the new pigtail. I also took the gray wire from the coil and connected it to the gray on the newe pigtail. I also took the black wire from the new distributor and connected it to the white/green for the shift interupt, which I cut when I attached. I then took the black wire from the shift interupt and attached it to the purp wire.
Hopefully by my description someone can inform me if I've done this correct or not.
Thanks for any help
skiprspd3
Just an update for whom ever may want to help me. I got the boat running. Aparently I had the shift interupt wired wrong. I unhooked the black wire and the boat started right up. Can anyone tell me how it is suposed to be hooked up.
Thanks
