Eska won't stay running!
DanielTTU
I just purchased an 82 Eska 15hp outboard. I replaced a few carb gaskets, and spark plugs. It will start on 3 or 4 pulls (if choked) and runs for 5 seconds like it is full throttle. It then dies. One time I got it to run longer by constantly pumping the fuel line bulb. When I stopped it died. But that method has only worked once so far. does anyone have any ideas on what this might be? I am not all that mechanically inclined, but I try. Thanks in advance!<br /><br />Daniel
steelespike
Re: Eska won't stay running!
You have a fuel supply problem.Go through it from tank to carb with special attention to cleaning.<br />Dont forget the vent,dip tube and any filters.
