eska tecumseh parts
narwhals
i found a marina in arizona that came across some tecumseh and eska parts.marina services 623-703-0393. i had some extra time so here is the list of parts.the following are all eska part #s 190128 body pump kit(2),26364 gasket cap(4),26617 gasket column(4),26619 gasket(3),262288 oil retainer plate(1),26620 top plate gasket(6),510244retain ring(2),96167 gasket(4),96223 exhaust gasket 30191(7),96177 o rings(6),96224 adapter gasket plate(9),96225 exhaust top gasket (6),96226 column top gasket (9),96295 engine shaft gasket(4),97660 outboard motor set(2),96972 engine base gasket(3),97661 gasket kit 3229 (1),1905047-60788 2 blade prop(3),46051 eska prop(2),510242 rings 1 set,The following are all Tecumseh #27136A fuel drain(1),29942 T-600 spool start(1),30547Abracket set (1),310149A rings T-1050 (2),310190 2 pieces(1),310268 ? (3) 31839 power screw(1),31413 spring(1),470102A reed T1200(1),530152 ? (1),510287A gasket(11),510217A gasket(11),510310 baffel gaskets(6),510247A gaskets(14),510305A top motor seal (4),530104A wrist pin bearing(1),530147 crank bearing(1),631078 screw(1),530150 bearing(2),570425 bearing(2),590414 adj. rod(1),590434A pulley assembly(3),590518 mounting bracket(1),610851B magneto(1),630932 inlet needle(1),630932A inlet needle(1),630953 pump element(6),631023 float(2),631553 screens(4),631555 gasket valve(6),631556A pipe cover(4),631725 inlet needle(3),632259A gaskets(16),631893 carb repair kit (1), i hope this helps someone.
