Eska 5hp
rdbateman
I just bought an ESKA 5HP from pawn shop with noe documentation. Any user manuals out ther? Trying to find correct gap for spark plug. Thanks!!!!!
M
mrcrabs
Guest
Re: Eska 5hp
check my signature link for lots of information and post your model no. so we can help...
and Welcome to Iboats:D
chances are its .35 but w/o model no.?
rdbateman
Re: Eska 5hp
Thnaks Chief! By the way, where would I finf the model number?
rdbateman
Re: Eska 5hp
FYI The only info I can find on motor is OUTBARD MOTOR: ESKA 1928-A BLU SER# 24500433
rdbateman
Re: Eska 5hp
thanks for all the info. not getting any spark to plug. any suggestions?
M
mrcrabs
Guest
Re: Eska 5hp
points must be set when they are on the mark at the highest spot on the lobe
check
Coil
Points
Condenser
high tension lead, "plug wire"
also you may want to check the magnets in your flywheel...its not totally unheard of for one to go bad.
