ESKA 5 HP spark plug ??
ADUKHNT
Model #1142-B SN 32995 the metal tag reads 634-07D and 4817150 it is a Golden Jet 500. Which powerhead ie it and what should be the correct plug?
I may be dumb but I see no shifter so I am assuming this thing is a true direct drive-always in gear...is that correct?
steelespike
Re: ESKA 5 HP spark plug ??
It is a 66 using a Tecumseh V51 power head.J6C plug set at .030. points .020.Fuel mix 16:1 useing TCW3 rated oil.I believe the 634 is a power head Type number.
