Envinrude temperture buzzer
gaylord1931
hello all, i have a 1992, 175hp envinrude, after running for a few minutes it goes in SLOW mode until you back throttle off to 2,500 rpm, i have replaced both temp sensors but that wasnt it, i have to unplug both sensors and the fuel vacumn sensor for it to run alright and horn to not go off, it is not getting hot i have checked the top of the heads with a digital thermal meter and reads about 160. I also took VRO pump off and put a new double fuel pump on it and premix my gas with full synthetic HD100. Does anyone have a answer to what could be going on? Thanks
emdsapmgr
Bad vacuum sensor? Bad power pack? ground short in the temp switch circuitry? That could include a grounded wire in the control box circuit.
Fed
Could the vacuum switch be doing exactly what it's supposed to do?
oldboat1
Sounds like you were at the top of a normal range when you measured temp -- so pretty good chance you are overheating at some point, imo. Should look for temps between about 140 and 160F (maybe under 140; shouldn't exceed 160).
I would consider replacing the impeller, checking and testing t.stats -- additionally, may have some blockage somewhere, particularly if running in salt water or a lot of debris/silt.
