Envinrude flooding out
Jet Sled Junky
My 1990 Envinrude V-4 115HP 2 stroke engine has a jet drive lower section. Bought boat a year ago with no issues...recently the engine starts fine, runs good but after a couple stops for fishing the engine floods. The oil injection has been dismantled from previous owner and I have mixed fuel/oil with no issues. The starboard lower cylinder floods bad, I have to remove cover, remove plugs (soaked) then crank the engine to blow out the excess fuel. During the cranking of the engine to blow out fuel, I also disconnect the fuel line to prevent fuel from entering the engine all together. The engine throttles are OMC controls assuming 1990 as well.
Any suggestions? I need to get a manual as well....thanks in advance!
Bosunsmate
With engine off and priming the fuel bulb does it go hard and stay hard? If it leaks a bit then the float and needle valve/seat for that cylinder may be worn
Bosunsmate
It should stay hard for a minute or two.
If its not that check spark on that side jumps a 7/16 gap
Honorary Supreme Mariner
Trouble shooting starts with a compression test on these crossflow engines !
8928hpj
Sounds like the needle in the carb is staying open to me.. May need to do a carb rebuild
Jet Sled Junky
Still in dire need of assistance....had both carbs rebuilt (looked clean inside) and replaced the old plastic bowls which were warped with aluminum ones (thought this was the problem as gasket wasn't sealing completely)) but still had the issue of flooding out after engine has ran and gotten warm then you shut if off for awhile. Got online and read that maybe the fuel pump was bad...used a small fuel tank and connected it directly to the fuel line connector on the engine. Lifted the small tank above the engine for a gravity feed and engine ran great! Couldn't get a rebuilt fuel pump so I bought a rebuild kit for the pump and reinstalled, same issue? Any ideas?
oldboat1
reasonable to think the main tank might be an issue. Contaminated fuel/water possibly settled at bottom of tank.
