Engines Draining Deep Cycle Battery
OldPacemaker1971
Hi, I am hoping that someone can assist me with this problem. I have a '71 Pacemaker with 1982 454- 350 Crusaders Engines. Each engine has it's own battery while the starboard engine shares usage with the house. The problem I am having is that whenever the engine is connected to the battery, drains the battery within 30-minutes, there is a burning smell and the positive wire that goes to the 12 volt panel also gets very warm to the touch. The battery also sparks when connecting the negative cable (indicating a power draw somewhere along the engine's circuitry) to the battery. Once I disconnect the engine's negative 12 volt cable and leave the house cables connected to the battery, the house wire cools down and the battery no longer drains. Do you think that this could be a bad ignition switch or perhaps the starter solenoid is sticking up? Thank you in advance for any information.
Lyle29464
Re: Engines Draining Deep Cycle Battery
That much draw makes it simple. Check big ticket items ( draw) I would unhook the alternator first. Then move to other large items, fridge?
OldPacemaker1971
Ok I will check the alternator. The refrigerator is 120volt A/C so I guess I can rule that out. I was thinking that the problem is within the engine's electrical because the battery only drains when the engine cable is connected, disconnect the engine cable, the drain stops. Even testing my trim tabs which draws 15-20 amps did not drain the battery that quickly and they were installed after noticing this problem..
