I have a Johnson 150 Bombardier saltwater edition.model number J150PXSRB. I just replaced the power pack, rectifier,35A, and H/T-Supp Leads 6 of them, because engine was running rough. Just tested it out and ran 3/4 of lap full throttle. Ran real good. Then made a weird noise after I got up to 3000 rpm. Slowed down then pushed throttle to go fast and engine started to run ruff and would not pick up speed. Engine doesn't die just runs ruff when you give it gas. Not sure what I need to check now.
