engine wont start
plou
I have a 1986 bayliner capri 1950 was sitting for a couple of years i changed the battery terminals cause they were rusty and put a new battery on it but engine wont turn over i only get the gauges lite up no noise up in the engine please help
mxnocean
Re: engine wont start
This could be a series of issues, here is a list to trouble shoot the problem
1. make sure battery is fully charged 12v or higher, 2. make sure a good proper ground is connected and terminals are on tight. 3. check starter relay for power on the ends and is wired correctly. 4. ensure key switch is wired correct. if all is good time to check starter for power. when turning the key is there a click either coming from the starter or starter relay. If starter relay clicks it could be possible bad starter relay, if starter clicks it could be a bad starter, try taping on it with a hammer lightly becuase the starter solenoid may stick. Here is where it gets fun 5. if all power is good and power is getting to starter (all 12v) then it could be that the engine is froze. If the engine is froze then time to bring the tool set and start pulling the engine apart and find whats cuase is to do so. If the motor ran fine then just parked one day for 6 months, I could be the pistone are stuck to the cylinder walls. easy way to find out is take of the heads (dont strip the bolts) and see if the piston rings are rusted or what ever the cuase may be. Hopefully its just electrical.
Frank Acampora
Take off the engine hood. Push in on the key while in the start or run position. If you see the chokes close or hear them click, you have power to the engine. Next check the neutral interlock switch (brown switch next to the bottom carb.) if the linkage is not moving the arm properly and depressing the white button, the engine will not turn over. If the switch button is being depressed and there is no power to the solenoid, (yellow wire) then the switch might be bad. Have a helper jump the switch and try to start. If it starts, the switch is bad.
