engine wont start 3.0
yobawoi
Re: engine wont start 3.0
engine turns over but no spark 3.0 glp-c any ideas thanks Roger
Roger, make sure the kill switch key is on. Just spent 2 hours with this last night myself. Fortunately, simple fix.
Don S
Your GL-C should start with the kill switch missing, but it will die immediately when you let off the key from the crank position to run. There is a hot start wire from the starter to the ignition to keep the voltage as high as possible when cranking.
On that note, is the battery charged up and cranking at a normal speed. Weak battery = no spark.
Here is some further troubleshooting info for the EST ignition.
View attachment Delco EST.pdf
roger100
Hi Guys, thanks for help. Let you know results when I get back to boat. Roger
