Wondering if this would cause my johnson gt 150 to take around 10 seconds to get on plane? Motor is mounted on a 5 inch jack plate, and has a step in the hull. Center prop shaft is about 6 inches below hull and the plate is about inch and half above. Should I raise it an inch?
According to the normal rule,your anti cavitation plate should line up with the bottom of the hull.Yours is probably an inch high.Could be cavitating,which will slow down getting out of the hole.
1) If you ski/tube its right......2) If all you do is fish it need to be raised up about 2 inches, bottom of hull should split water intake holes. Cant tell if that a old style Raker prop without vent holes, if no holes drill some.
