Engine will only start/run with manipulation of throttle linkage
chadgrow
Help please,
I recently rebuilt the carburetor on my 1992 28 horse Johnson, I followed the OMC repair manual and watched several online tutorials. After the reinstall I replaced the fuel line and filled the tank with new gas. However when I go to start the motor it wont start unless I press on the throttle body linkage a little and the only way it stays running is if i keep pressure on the linkage. I adjusted the low speed needle valve out three turns after gently seating it per the manual however I cant get it to run to make the adjustments any farther. Nya help would be greatly appreciated.....
Thanks in advance!
bonz_d
If it was running before the rebuild then there is something tat was not put back together correctly. Pull it off and go thru it again, slowly and carefully. Check that you didn't put the float in upside down too.
Oh yeah, Welcome aboard!
oldboat1
It sounds like the carb is not synced with the throttle cam -- you are opening the carb manually(?) That low speed setting will be an initial setting (need to tweak it for best operation), but three turns open sounds rich to me for an initial setting. Might see if it will run with an initial setting of 1 1/2 or 2 turns, then adjust. Carb has to begin to open at the throttle cam mark, though, via throttle operation with the twist grip.
chadgrow
I checked the carb and it appears to have been assembled proper. I am manually opening the carb. Not sure I understand the carb opening at the throttle cam mark, can you please elaborate. Also my boat has a remote throttle. I have been reading various threads and bits I find trying to figure this out and believe I interpreted someone explain that if the fly wheel is manually spun that the carb should open at some point during the rotation. If this is accurate mine does not. My apologies, I am new to working on outboards and any help offered up is greatly appreciated......Thank You
oldboat1
best thing to do is probably disconnect the remote controls at the engine. Standing in front of the engine, throttle control will be on the right. Need to look at what happens when the throttle is advanced (plate under the flywheel will turn). You can rotate the throttle plate by hand to see what linkage moves. That plate will bump a little roller above the carb, and will open the carb so more fuel can pass. Do a search under link and sync for a better description, and use parts blowups along the way (evinrude.com, among others).
chadgrow
Thanks, bonz-d & old boat,
I have some things to try now, I will post my results soon. I am very appreciative for folks like you willing to take the time to share information to help others....
chadgrow
Been raining for the last few days and haven't been able to attempt the link & sink. With the time to think, I'm not sure if I ignorantly messed w/ the timing screw when trying to remove the carb. If I did will I still be able to get the thing running following the order in the omc manual, or should I skip to timing check. Also I've read that the timing check requires a test prop, and that proper timing shouldn't be attempted until warm up. Aditionally is the timing spec the same for the 20 or the 30 horse, the omc manual doesn't specifically site the 28. Sorry for what I'm sure to most seems common sense but I'm new to this type of thing.
Thanks in advance
oldboat1
yeah, a bit in the weeds there. warm up is important when doing carb adjustment. I don't have test props for all of the engines I tinker with -- don't rev them when working in a barrel -- short burst to adjust carb, when appropriate. Never sustained running at high rpms. Leave the hose running in the barrel (and never try to make adjustments while running on a flusher -- need back pressure).
Not sure you can reach the cam follower adjustment screw on your model without some disassembly (maybe the starter). Don't need to have the motor running (or warm) for that adjustment. (that's the "sync" -- carb has to begin to open for fuel flow at the point the follower lines up with the mark on the throttle cam.)
