SeaKing15hp
- Aug 3, 2005
- 42
I have finally gotten good fire to both of the cylinders and I had the carb cleaned on my 1982 Sea King 15 Hp. It starts and runs when choked, and will idle roughly until you turn it off. I think that its just running way to rich. The problem comes when you try to turn the choke off.. its like you turn the entire fuel system off. I have found that it runs best when you rapidly push and pull the choke on and off. What would cause this? Thanks in advance.<br /><br />Jacob
