thisuldoit
Thread starter- Joined
- Jul 23, 2006
- 102
I have a 1989 Wellcraft Eclipse XL with a 4.3L Mercruiser engine. It has been sitting for three years. I went to take it out today, and with a little trouble and starting fluid, I was able to get it to start using the throttle only button and giving it full throttle. I would then back off on the throttle and let it run for a little while with the throttle only engaged. When I would try to move the throttle back to the neutral position the engine would die. Is this a switch issue, or a carburetor adjustment issue, or what?
Thanks!
Thanks!
