Engine vibration at idle in neutral
Jimmy323
Ok. So I got a little too close to the bank Saturday and my prop was torn up. About an inch or so per blade was ripped off. Sounded like it hit rocks. I was at a marina and am quite sure that's what was in the water. Sounded bad, but I had prop replaced while I was there. Mechanic said the shaft was not bent. He put a brand new prop and whatever is behind the prop. When the boat is in neutral, and the prop is not turning, there is a definate vibration from the engine now. When I put in in gear, forward or reverse, it's hardly noticeable. But in neutral it's pretty bad, compared to no viration at all before. I assume it is something between the outdrive and engine. I am mechanically inclined and have built many car engines but am not sure what to look for on this. It's a 1994 Stingray. 4.3 litre Mercruiser. All original equipment with 285 hours on it. Any help would be greatly appreciated. Thanks.
Re: Engine vibration at idle in neutral
Ayuh,... Welcome Aboard Jimmy,...
Pull the drive, 'n try it...
That way you'll know whether it's the Drive, or the Motor...
Jimmy323
Thanks. I am not familiar at all with boats. I will google it. Do you mean the whole outdrive? Sorry for the lack of knowledge. Haha. I haven't had a chance to look at it but was thinking there must be something like a driveshaft that is between engine and prop. I'm sure there are gears or a shaft of some kind. Other than the shaft the prop is on. I just dont understand if the shaft is not bent, how something farther in toward the engine could be? I would have thought the prop shaft would have bent first. Again, i'm not familiar with boats. Thanks for your help. Will keep you informed as I will check it out tomorrow evening.
dubs283
Any other suggestions?
yep
do what bondo suggested - thats the first step in your troubleshooting - isolate the drive from the engine
sure, anybody can guess as to what the problem is - from "its all in your head" to "you need a whole new engine/drive assy"
until YOU start looking at it, we have no idea what is going on except you have a vibration in neutral
so pull that drive and run the engine and let us know what you find
Phfantasm
I am sure someone else may suggest that when you get the outdrive off, take a flashlight and look in and inspect the splines on the coupler, if they got damaged you could get a vibration... which would be the begining of a possible breakdown later on water... if the splines dont look good, change it.
