1974 Johnson 115 hp lower unit UPDATE/HELP: NO REVERSE!!!
ezeke
Re: 1974 Johnson 115 hp lower unit UPDATE/HELP: NO REVERSE!!!
It is correct to make your cable adjustment in neutral, not reverse: Move the lever to neutral and verify that the propeller is free; Move the throttle fully forward and back to neutral; Then adjust the cable to slip on without moving the shift lever.
Joe Reeves
(Centering Shift Cable)
(J. Reeves)
When all is as it should be, the proper method to adjust the shift cable is to disconnect the cable from the engine. Move the shift linkage on the engine to find the center of the play in neutral, and when found, leave it centered.
Now, grab the end of the shift cable sleeve, push and pull it to find the center of the play there, and center that play.
Adjust the trunion on the threaded portion of the shift cable so that the centered play of the cable lines up with the centered play of the engine's shift linkage. Install and lock the shift cable with the retaining clamp in that position. That's it.
