Engine troubles
shreve soule
My 1990 25hp Johnson outboard starts fine and runs<br />fine for a while. All of a sudden it begins to jump and lose power stalling if I don't ease back on the throttle and then starts and idles fine, but stalls when I try to increase the throttle.<br />Can any body give ideas as to what might cause this?
Hooty
Re: Engine troubles
Whenever it starts all that jumpin' 'n' jivin', give the choke a good bump and see if it smooths out or not, If it does, you've got a fuel delivery problem. Check tank vent, leaking fuel line, defective fuel pump or dirty carburetor(s)etc.<br />If it doesn't help when ya choke it, post back and we'll go from there.<br /><br />g'luck & c/6<br /><br />Hooty
shreve soule
Re: Engine troubles
Thanks for jogging my memory. When I choke the engine it picks up power. Problem is my finger can't pump that fast to get up on plane !
