Re: engine torque
Aerobat,
Agreed. The advantage of over propping usually has the best benefit when a boat has considerably more power than the operator wants to use.
Take for instance my boat. She has a semi-displacement hull, weighs about 17000 lbs and has twin 351 Fords rated at between 235 and 240 HP each at between 4200 and 4400 RPM, depending on what spec you are looking at. I have her propped for ~3900 RPM WOT. She will do ~23 knots wide open and I can cruise her at ~17 knots at ~80% load if I want to, but I don't. My normal cruise is ~8 knots, 1800 RPM ~15" manifold vacuum. I have what I consider to be a compromise over prop. I could probably add a bit more pitch and get slightly better 8 knot economy if I was prepared to sacrifice some top speed, but I prefer to have that in reserve for emergency use only.
How much fuel does this save me, you might ask? I don't know for sure, but I have relatively accurate fuel flow indicators on the boat and in my motor home. I have done experiments with the motor home running a constant speed on a constant grade, shifting between direct and overdrive. The higher gear consistently resulted in ~3% less fuel burn even though the mixture was richer at the higher manifold pressure. This might not sound like much, but the savings are there and they are real.
My best improvement economy came from the conversion to EFI, which was done after the prop change. I did one engine at a time so I could compare data. Both engines were healthy and in a fine state of tune. At 8 knots the EFI engine burned ~20% less fuel than the carbed engine. I found no measurable difference in top end power.
In a road vehicle my feeling is that there is no such thing as too many gears. I agree that a controllable pitch prop, or some kind of variable speed gear box should be beneficial for economy in a boat that needs a wide range of speed, but I don't know just how practical that would be. For now it looks like we will have to live with the limited options we have to tune the engine, prop and hull combination to our operating style.
