Engine to Fuel Line; 'O' Ring? '87 175
TONY H
Just noticed today that when I pump the Bowl to get gas into the carbs that I get Drips where the fuel line connector meets the engine is there some 'O' ring that sits there that may have deteriorated in 23 years?
robert graham
Re: Engine to Fuel Line; 'O' Ring? '87 175
The quick disconnect on the front of motor may be worn. You can check the seal, buy a new one or eliminate it entirely. A worn seal there can cause gas to leak ouy when you're priming it and air to leak in when the motor is running. It's an easy fix.
TONY H
This would tie into a intermittent Idle issue I have been having.
I bought a new Quick Disconnect End. It fits snug. I was surprised to not find a rubber Seal on the end.
robert graham
I almost never disconnect mine, and I've heard some folks just eliminate the quick-disconnect with a straight piece of fuel line through the rubber gromet on front of motor, just eliminates one more possible place to leak. I've never had any trouble with mine, but if I do then may consider eliminating it.
99yam40
O-ring should be internal of the quick connect.
Look at where it rides on the other part to see if it has damage or corrosion if you still have leaks
