Re: Engine Timing..
I can't view pictures from work, but bent/broken push-rods can certainly have an effect on a cylinder's proper function!
I'd be concerned about finding out what caused that. Have you ever hydro-locked the engine?
At this point, for #4 piston, your best bet is just to play the "wait and see" game. More likely than not, it was the bent push-rods. Just check out what you can, and hope for the best.
Worst-case scenario; you get it all put back together, and you have a weak cylinder. If you can live with that, then there's no problem.
If you decide you can't live with it, the engine's going to have to be pulled, and you'll be no worse off then, than you are now. You can pull it now 'just in case', or you can wait and see if it really needs to be pulled. The heads will still be good as new.
My guess is that it will be fine after you get her back together. Even if it's not, 1 weak cylinder out of 16 shouldn't be too hard to live with, unless you're really really picky.
But seriously, we need to figure out how you bent your push-rods.
Good luck!
Good luck!
