FreeBeeTony
- May 15, 2002
- 3,997
If an egine's timing is too far advanced will this gave any affect on the WOT RPM's? I recentky rebuilt an older Mercruiser 165 IL6. I had a hard time finding the timing mark on the vibration damper and the readings on the timing flange on the block are not visible. Assuming the middlie of the timing flange is 0 degrees, I set the timing mark to about 1/2 inch advanced. Mid way between the middle of the timing flange and the end. The engine is only turning 3500 RPM's at WOT and its running hot (>180). The boat is a 20' Grady White Gulfstream with a 17" pitch prop.
