engine temp reading cool
andyj
as an update if you read my last question - I changed a thermostat out on a 1989 Merc 350 Mag. Now it idles at the correct temperature, when under way or WOT the gauge drops and reads 100. as soon as I slow down and idle again, it goes back to 145. Any suggestions to get it to hold constant?
Re: engine temp reading cool
Was the T-Stat Housing in Good Shape,..???..<br /><br />Is the O-Ring in the Right Place,..??....<br /><br />Have you checked for Flow at any points in the cooling system,..???.....
andyj
yes, yes and yes. Everything seems to be functioning just right. Except when you hit it from idle, the gauge drops down. after 20 minutes of running, I'll stop and open the hatch and use an unscientific finger test on hoses etc and compare with the "good" engine that does not have any issues. I think I might try moving the gauge wires to the other heat gauge to see if I get the same funny readings - at least that tells me more and further isolates the problem, and I won't have to replace a good gauge.
johnbo
I've having the exact same problem on my 4.3L V/P unit. It appears that I'm getting some debris through the water system. The first time, it was a chunk of the previous impeller. Now, it seems to be just little bits, like smaller than a pencil lead, that are getting wedged between the sealing surfaces of the thermostat. <br /><br />I've not figured out a good way to flush the system at this point. Due to the cool water at the time of my tests (March), I was figuring that the thermostat was not opening very far at all, even when working normally. <br /><br />However, it is certainly not obvious why it warms up again at low engine loads and cools down at high engine loads. The only thought is that the little chunks are transients and at lower engine speeds the vibrations are less, so there are fewer chunks floating around. <br /><br />I've tried, for a short time, to remove the thermostat and run the engine, but this didn't seem to help. There are comments on this list that this can be a bad thing, due to the inability to transfer heat to the water at high flow rates. Personally, I don't understand this, unless it has to do with turbulance in the water jacket, but I'm still not convinced. <br /><br />The next step, if this re-occurs, is a homemade thermostat gasket with a small hole (1/4 or 1/2 inch) to restrict the flow slightly.<br /><br />I'll be watching this thread to see what you find out.<br /><br />Later,<br /><br /> johnbo
andyj
Thanks John - at least I'm not the only one. I have heard people talk of "Backflushing" an engine - How is that done?
