Texasmark
- Dec 20, 2005
- 14,984
Got a '02 90 Merc. Had a stuck thermostat when I bought it....found out the first time I went to the lake and the overheat horn went off. But It has a pressure relief valve also so if you hook her up and get some water pressure into the lower unit she opened the press relief valve, which bypassed the thermostat and it cooled ok....got me back to the dock.<br /><br />Pulled it out but might want to put it back in. But that is another topic.<br /><br />Teleflex Morse makes a dash mounted engine temp kit for OB's. I noticed about an 1/8" pipe, maybe 1/4" tapped hole (plugged) on the engine's water jacket at the top which I presume is where the temp gauge sending unit goes.<br /><br />Has anyone added an after market gauge like this and if so do you just route the tube along with your electrical wires from the engine to the dash?<br /><br />Any thing one should know as far as gotcha's are concerned?<br /><br />Thanks,<br /><br />Mark
