The 470 is counterclockwise, that is looking from the aft looking forward at the flywheel. So BOTH OF YOUR 470's are CCW engines. If you are looking at the front of the engine from the bow the rotor on the 470 crank or the harmonic balancer on the 250 would rotate clockwise. When determining rotation the convention is flywheel rotation looking from behind the engine. So if your props are different then the rotation is reversed in the outdrive.
