i recently acquried a 1979 cobalt with an 800 omc stern drive. i had problems all the way. i put new starter, coil, plugs, and points in just to get the boat to start. i had to ship the upper away to get the housing replaced. i put the boat in for the third attempt today and joyously got to run the boat around the lake finnaly. everything seemed to be dandy until i decided to open her up a bit. as soon as i did open her up, she stuttered and stalled. it didn't want to start back up. i jiggled the supply wires to the distributer and it started after several attempts. it kept stalling, even at low rpms for a while, but after 5 min or so, it seemed to run fine. i took it easy till i got near the boat launch and opened it up again and had the same results.
where should i start?
