Patchwork1
- Apr 13, 2011
- 5
So we dropped the boat in the water, and it was running fine for about 30 min. Then the engine bogged down and shut off. We were able to restart it a few times, but it was barely able to stay lit, and ran poorly. Once we got it back on dry land we did the usual stuff.
Checked the spark plugs
Checked the coil/distributor
Checked the carb and fuel flow
Checked the shift interupter switch
We then noticed a loud clang when we would crank the engine. It doesn't happen when the engine lights and runs poorly for a few seconds, but when the engine is just turning over this sound is present. The block and head was just professionally rebuilt by a local shop that works on these engines specifically. Any thoughts?
OMC cobra
4 cylinder 3.0L
The boat is an 88' Chris Craft
Thanks!
OMC cobra
4 cylinder 3.0L
Thanks!
