scdeerslayer
- Apr 9, 2010
- 12
I have an 83 johnson 200 it runs fine until heated up or cut off after running then it might run fine or it might bog and if given more fuel while bogging it will cut off. If while bogging i play with the throttle it might take off and run fine. It just feels like it is cutting in and out. I have taken the carbs apart, took the fuel tanks out and cleaned, new fuel lines. I don't think the fuel system is the problem cleaned it just to do it. I think it is electrical but I don't know where to start. It runs great in the yard but it seems to sometime idle lower can go from 1000 rpm to 500rpm but it won't bog when given gas. Also would being under a load effect it if it's electrical. It also seems to be getting worse. Any help will be appreciated. Thanks.
