My boat is a 1979 27 ft Carver Monterey Mercruiser 228 305 4barrel - Alpha Drive
The engine stalls when shifting gears
Last year the boat engine would stall going forward and reverse I had to jack up the Idle to prevent it from stalling The boat was only taken out a couple of times
This year the engine still stalls and jacking up the Idle does not work.
With engine running I manually push the Y shift plate (barrel is in the middle) the button on the Shift Interrupt Switch is compressed- engine stalls -
With engine off and the shifter is put in both forward and reverse the shift plate moves and the Shift Interrupt Switch button is compressed
With the engine running the shifter is put in forward the shifter plate barley moves and the SIS button is barley touch- engine stalls - when put in reverse the plate moves and the barrel presses the SIS button -engine stalls
Disconnected the lower shift cable and manually pushed and pulled the cable - it is smooth but a little stiff. There is no history of having any difficulties shifting in and out gears (except for stalling)
Engine will not heat up - thermostat was tested - Exhaust manifolds and the thermostat housing are lukewarm
Intake Manifold is cold - choke does open (submitted a separate Post)
Your help is greatly appreciated
