Is it normal for my 75 85 hp merc. to smoke white smoke out the exhaust? not bad just a little.
N nshirley Cadet Thread starter Joined Mar 12, 2011 Messages 11 May 13, 2011 #1 Is it normal for my 75 85 hp merc. to smoke white smoke out the exhaust? not bad just a little.
J joezek Petty Officer 2nd Class Joined May 8, 2011 Messages 137 May 13, 2011 #2 Re: engine smoking If it's a 2 stroke where you mix oil + gas together then it's going to smoke definitely. Mine's running 50:1 gasil ratio and it smokes a lot when you first start it, and half as much the rest of the time. The more oil it gets the more it smokes.
N nshirley Cadet Thread starter Joined Mar 12, 2011 Messages 11 May 13, 2011 #3 Re: engine smoking yes it is a two stroke i use the same ratio, thank you very much.
