Engine Slow turnover while starting
rla0002
I have a 1988 48 hp johnson tiller motor with push button starter. My issue is the engine turns over very slowly and will drain a fully charged battery very quickly. The following items have been replaced. Battery (Several different batteries), battery wires (4ga), solenoid and starter. Issue still occurs. I have now determined that when removing the spark plugs (No Compression) motor turns over at required speed. When spark plugs back in, back to slow turn over.
Now with this being said, at random times, usually after 6-8 slow revolution starting attempts, the engine will turn over full speed, start up and will not have an issue until engine is cold again.
rla0002
I would like to add, I have used several different batteries. I have hooked the battery up to a running vehicle with jumper cables as well some times it worked, sometimes like i mentioned before it took multiple trys. I have had this engine for several years and the problem has worsened over the years. Now to the point I cannot get the engine to turnover at full speed anymore.
I have now come to the conclusion that it might be something internal within the engine block. The reason I have come to this conclusion is: I have bypasses the solenoid with a direct connection, battery to starter (both new and old one) and still have same slow revolution issue. Key Point here--->When I manually spin the flywheel it has an increased resistance to rotate in the same location during a revolution.
Any thought with this additional information?
Bosunsmate
How much increased rotation? Have you done a compression test?
Have you tried grabbing the flywheel and seeing if you can move it off centre? You shouldnt be able to move it more than half a hairsbreadth
rla0002
Increased resistance, not rotation. Their is no horizontal movement off center by the flywheel. The flywheel is tougher to turn at certain locations during a revolution. Is this normal? I believe this to be the factor resisting my starter, resulting in a slow revolution during starting attempts. I have never done a compression test. I don't know how that would play a factor in the slow starting revolution issue. But I am no mechanic.The engine runs fine once I get it am able to get it started.
Thanks for your assistance.
mla2ofus
Pull the starter, disassemble and put some grease in the shaft bushings. My Force did that right after I bought it and this fixed the problem. Has cranked fine ever since for 7 yrs now.
Mike
jakedaawg
If you you replaced what was stated with new OEM material then I would look at the batteries, are you buying cheap ones? what is the CCA listed? I guess besides the battery I would clean the ground at the starter.
rla0002
I will replace the battery tomorrow and clean the ground on the motor at the starter. In my past history with this motor, it requires a minimum of 660 CCA and always works with a brand new battery. For some reason when I leave the engine connected to the battery for more that 3 day, it will drain the battery down and even after charging it, it some how "kills" the battery after a few uses. At this point, I usually have to return the battery to the store, they run a test confirming the battery is "dead" (not chargeable) and replace it. This is all in a period of roughly 1 year. I have done this cycle for 3 years now. I know this sounds crazy but it's the truth. My current battery is only 7 months old and came fresh off the charger. Basically, I am tired of dealing with this battery drainage issue and trying to find a solution. Also, I no other accessories running off the battery to possibly drain it.
Thank you all for your help.
Fed
Have you tried that with the spark plugs removed? If it still has a stiff spot you may have a failing drive shaft bearing, test by removing the gear case.
Battery drain could be through the rectifier, disconnect & see if it goes away.
Bosunsmate
if there was a problem in one cylinder causing the piston to snag a compression test may show it, but i agree about removing the leg as someone else had a problem like this recently
