Engine size need new prop.
Joel09
I have a 1969 runabout glastron v157.
I have a mercruiser engine and I need to know what size it is, because I need a new prop. I went to the marine shop and they told me that I need to know the size of the engine.
Don S
Re: Engine size need new prop.
Moving this to the prop forum. You are also going to have to post what engine and drive you have, along with the gear ratio of the drive. Then you can get an estimate of what prop you will need.
jestor68
The Glastron V-157 is a 15 ft tri-hull bow rider. The stern drive version would likely have no more than the 120 HP engine; which is a 153 CI 4 cylinder engine. The drive uses a 1.98:1 gear ratio. 383_00g.jpg
Joel09
That looks exactly like my boat that's exactly the information I needed thank you so much!
Ayuh,..... Welcome Aboard,.... If ya answer these few questions,... We can figure out just what prop ya need,....
