Engine serpentine belt, photo, need advice
KRS
Banned
My '00 Jeep Grand Cherokee 4.0 has 100,000 miles on it. I think this is the original serpentine belt. I was checking it today and it appears to have a very uniform crack across it. Is this a seam or a sign that it's time to replace it?
If replacement is necessary, is OEM the best or should I just go to NAPA?
Thanks,
KRS
bjcsc
Re: Engine serpentine belt, photo, need advice
Yes, all of those little cracks in the ridges mean it's past time to replace it.
Any new belt is better,...... than no new belt at all.
NAPA is fine, they're nearly all made by gates anyway...
Skinnywater
Looks like the original to me.
Be careful not to over tighten the new one, It'll put additional stress on those other components with 100k on them.
I get tremendous service life out of my waterpumps, idlers and alternator bearings by running a belt a little on the slack side.
SuperNova
Definitely new belt time. It runs on an automatic tensioner that tends to get sticky somtimes, so check it as well and replace if necessary.
Stan
Skinnywater
Stan
They must have changed that in '00, my Wrangler has a '99 GC engine in it and it's still a manuel adjustment.
KRS
Banned
Thanks all, sounds like it's time for a new belt. I'll check the Haynes manual and see how it's done, it should be something I can do.
KRS
rwise
Its done with bad words and scraped knuckles :rolleyes::D:D
Coors
Get a ratchet and put a piece of pipe over the handle for more leverage, to move the tensioner. (you need one arm to pull off the belt, while putting pressure on the tensioner).
SuperNova
Should be a 1/2" square drive ratchet and it'll fit right into a square hole at the pulley end of the tensioner(silver thing just to the left of the fan pulley in your picture).
Stan
KRS
Banned
I was driving by a local shop, and they had a sign $49.99 serpentine replacement.
I stood there while the guy and a helper put a new one on in less than 3 minutes!
It's done, and it wasn't too expensive... but I'll do it myself next time.
Thanks for the tips and tricks guys.
KRS
ZmOz
LOL...I changed mine today, lost about a quart of blood and scared all the neighbors. :D My 'regular' cherokee was never designed for that long inline 6...:rolleyes:
BF
did you guys held onto the old belt? I always fold it up and either stick it with the spare tire, or behind one of the plastic panels in the cargo area. A broken serpentine belt is one of the things that can leave you walking... I feel better driving on secluded highways knowing I've got a spare.
qaztwo
Keep old one for spare in jeep.
rndn
Replace with any new belt. They all are manufactured to the same standards.
Reel Poor
That's like saying all tires are the same. Not true. You can definitely buy quality vs cheap belts.
KRS
Banned
We'll watch the wear on this one and replace it as needed.
