Engine S/N
FreeBeeTony
Thanks .Now for the questions;
1) came with a serpentine belt set up can I change to old school and replace the plastic timing cover with a metal one?
Bt Doctur
No
FreeBeeTony
Can I use the v belts with the plastic cover? Or should I use the serpentine set up but I have a belt driven raw water pump
Bt Doctur
You may have to use all the pullys and such . May even have to create some spacers but it should work.
If I can put a Bravo raw water pump on a Volvo gm v8 you should be able to do the belts
achris
More fish than mountain goat
Why would you want to get rid of the serpentine system? It's way better than vee belts. And much easier to just change the raw water pump to a 6 groove pulley... One pulley instead of 4, and the associated headaches...
Chris
achris
I guess my only concern is adding the "Bravo" raw water pump.
Pull the Vee belt pulley off it and put a 6 groove (serpentine) pulley on. Have a look at Dayco website, they have DOZENS of pulleys, I'm sure they probably make the one Merc use on the pumps anyway (Merc part number -807731T) ...... You'll also need a new belt, but any auto parts shop can supply that...
Chris........
FreeBeeTony
I a considering building a striker out of the engine that was I my donor boat. Just thinking at the moment
FreeBeeTony
Thanks for the info guys............Have decided to put the serpentine system on the donor block when I build my stroker. May have discarded the idler pulley by mistake but should be able to put something together w/the help of you guys!
achris
If you're looking for idler pulleys, Dayco website... Millions to choose from. ;)
